patchelect
Before I begin let me state that I'm not interested in suggestions for alternatives to CD's, thank you.
I am planning on installing a CD player in my '14 console and wondered if anyone knows if the wiring harness is already set up or if I'd have to run my own leads? I am planning on searching for an OEM unit. I've seen aftermarket units that are mounted against the interior wall with L brackets and a hole needs to be drilled to pass the wiring and I don't know if the necessary connections/connectors are in there already or not. I haven't attempted to look yet as I only recently got the truck and haven't had the opportunity to dig into it. My initial attempt at gaining information got relocated to the "Wanted" section because I phrased the title wrong. I'm looking for helpful input from others who may have done this or have the insight on how things were wired from the factory.
