dodgeowner123
- May 6, 2015
- 3
- 0
- 2002
- 4.7 Magnum
Ok, so i just bought my truck recently and i noticed that the rear speakers did not work and neither did the driver side rear window nor the lock. So I looked up and discovered the problem where the wires in the rubber harness between the door and body will split and not work. So i go to my driver side and see the problem. Its been broken before so someone had already tried to fix it. I didnt have enough wire from the plug on the door, so i just cut off both of the plugs on both ends and matched the wires and tied them together. Now i was able to get my driver side door window and speaker working, but whenever i went to the passenger side to do the same things, the wires coming from the body were different colors from the one coming from the door. And like an idiot i didnt look at the plugs to see which colors went to which color. So now im stuck and could use any help. Thanks
