tumtum512
- Sep 10, 2015
- 4
- 1
- 2005
- 5.9l Cummins
I'm have the 4wd indicator flash intermittent... it looks like a short somewhere, because there is not pattern with the intermittent flashing... just kinda flash on and off like a grounding issue.. happens mostly when driving... just had my Trans rebuilt, but not sure if they would have been playing with that... I did add fluid to the 5wd transfer case thinking that maybe it was a low level indicator, it was low, not anymore, and still having issue... they also reprogrammed my ecm and had a wiring issue with the ttva that has been resolved but worth noting since it was fine after rebuild.. any thoughts or suggestions? maybe the location of 4wd sensor on the case below? needs replaced?
ps this is my first post but I'm itching to show my doggy off! 2005 3500 5.9l automatic trans
