Adding auto dim mirror...
quietpeen
2021 TRX
Hellcat
Haven't seen you in a long time
From what i remember it can if the harness is in your truck for oem. For aftermarket i would guess you would be running some wires and tapping somewhere for power
chedched
Madison, WI.
2019 Power Wagon
Using aftermarket is exactly as described above. Find a mirror assy and tap power and ground. Not too tough. Using OEM, I don't know. I don't work for Dodge any more.
LB3711
Trumbull, CT
3.6L V6
Mine has auto dimming inside and out mirror. I know mine work off of the inside mirror that has the light sensor on it. I would assume youd need that too. Altough did late 3rd gens come with outside dimming mirrors?
I would go aftermarket. Much easier to do. Its not hard to run some wires and hook it up.
