Tools Needed:
Wire Cutter
Wire Stripper
Soldering Iron and Solder
Drill
Nut Drivers
Heat Gun
Materials Needed:
Wire
Shrink Tubing
Electrical Tape
1/8" Stereo Jack (RadioShack Part #274-246)
1. Disconnect Battery and remove the dash trim and radio.
2. Find the XM radio plug. (See picture #1)
3. Cut the brown/white wire and the green/white wire. Also, strip about a 1/4" off the black/white wire but do not cut it. (See picture #2)
4. Solder wires to stereo jack and splice them in as shown. (See picture #3 and wiring diagram)
A. Terminal 1 - Splice into Black/White wire
B. Terminal 2 - Connect to Radio Side of Brown/White wire
C. Terminal 3 - Connect to XM Antenna Side of Brown/White wire
D. Terminal 4 - Connect to Radio Side of Green/White Wire
E. Terminal 5 - Connect to XM Antenna Side of Green/White Wire
F. Tan Wire - Do Nothing
5. Shrink tube bare wire connections and wrap in electrical tape. (See picture #4)
6. Drill hole in a location for the stereo jack and install. (See picture #5)
This will allow to plug in an mp3 player and play it through your audio system when you select XM radio from the bands. You do not need to have XM Radio service, even a XM preview channel will work. This does not work with non XM radios. I am in the process of determining how to make this work on a non XM Radio enabled stereo.
