I don't mean to hijack this thread but can someone tell me what I need. I'm planning on getting a double din navigation and keep the factory speakers(4 speaker system). Not upgrading anything else at this time I mainly want in dash navigation. What wiring harness will I need? I looked on crutchfield and the harness they show is maybe $30. Thanks
The wiring harness adapter you need is the one to connect with the head unit you choose. If the new HU uses a proprietary connection, you'll have to get the specific complete harness or make one by getting something like a Scosche Chrysler pigtail and cutting/soldering the new HU ends.
If the HU uses an ISO connector, there is a Chrysler-ISO adapter. I don't recall Crutchfield nor installer.com had them when I was looking for one. I found one on eBay from UK; about $20.00 delivered.
I guess with a four-speaker system you probably have something like a Chrysler RBK. If that's the case, you'll need a different bezel for double-DIN and antenna adapter.
I have a thread in this sub-forum that will give you an idea of what you'd need and experience, although for a 2005. You really should consider speakers to get more out of a new HU. You'll see a comparison of some mid-level Kickers to factory speakers in the thread, also. They are noticeably better, reasonably priced and quite easy to replace.
