So I was looking around at some local installers that handle DVD players for my truck and came across a place here that does a CompuStar Drone setup. Similar to the viper setup, but that is all about I know since I have not researched it more in detail yet.
Drone Mobile by CompuStar
Found this under their "Drone Teen Driver" as capabilities
GPS tracking gives you the ability to pinpoint the exact location of the vehicle.
Geofence allows you to set a radius around a Point of Interest, notifying you if the vehicle is leaving or entering that area.
Point of Interest allows you to pick certain locations, notifying you if the vehicle has arrived or is leaving.
Curfew Violations lets you set what time you would not like the vehicle driven. If the vehicle is turned "on" between the set curfew times (ex. 12:00am - 8:00am) a notification will be immediately sent.
Keyless Entry allows you lock and unlock the vehicle at any given time.
Set maintenance reminders to notify you of maintance and improve the life of your vehicle.
Low Battery Alert will notify you when the vehicle's battery voltage is running low.
Speed Limit Alert will notify you if the vehicle's speed is past the set limit.
DroneMobile will notify you within seconds when an alarm zone or reminder (anyone of the above) is triggered.
Web control gives you access to the same features you would from your phone from any computer with internet access
