Amp wiring...which method is best?
Deviate
St. Augustine, FL
2005 4x2
So I have some options with the amps and headunit that I have. I have an alpine cde-9852 HU. It's older, but it works and does everything I need (although not all I want...nav...backup camera...). It only has 1 set of RCA outs.
I have 2 amps: 4 channel with two RCA ins and 1 RCA out (also has speaker level inputs) and a mono amp with 1 RCA in and 1 RCA out.
The options I see are:
1) RCA from HU to Mono amp and speaker level from HU to 4 channel amp
2) RCA from HU to Y-splitters to 4 channel amp and then RCA from 4 channel amp to Mono amp
3) RCA from HU to Mono amp and RCA from Mono to Y-splitters to 4 channel amp
#1 is how I have it currently. #3 just seems dumb. Would I lose or gain anything by doing option #2?
jhemi
wisconsin
it will all yeild the same results, i would just leave it the way it is
the codes
Houston, Tx
Magnum 5.2
glad I only have one sub and a mono amp to wire up!
Tapatalk Addict
quietpeen
2021 TRX
Hellcat
you could us an electronic crossover....1 set of rca's in and then the rca's go out o the amps.
