04dodgeram1500
- Apr 21, 2017
- 2
- 0
- 2004
- 4.7
Help Needed - Audiovox APS57E 2004 dodge ram install
Aps 57e - 2004 dodge ram 1500 4.7
no existing factory alarm system that i am aware of.
Tried the key in tumbler twice and only unlocks drivers door.
14 pin main harness
green/orange-tachometer – not connected
green/yellow-glow plug – not connected (not diesel)
dk blue – trunk release – not connected
brown/black (+) inhibit brake switch – white/tan connected at
brake switch
brown (–) inhibit brake switch – not connected
grey (–) inhibit neutral start switch – not connected
black/yellow (–) pulse during crank output – not connected
black/red (-) pulse after shutdown output – not connected
black/blue (-) pulse before start output – not connected
black/lt green (-) pulse after start output – not connected
lt blue (-) ground while running output – not connected
grey/black (-) inhibit shutdown hood sw – connected and
checked working properly (not grounding to frame)
black/white (-) horn output – dark green/purple (steering
column) working properly horn honks when lock/unlock
6 pin power start harness
blue – ignition 1 (+) connected pink/white
red/white battery 1 (+) connected red wire #1
green – ignition 2 (+) connected pink/green
purple accessory (+) connected to blue wire (ac blower)
red battery 2 (+) connected red wire #2
yellow starter output connected yellow wire starter
4 pin 2nd main harness
black chassis ground (-) grounded to chassis
white/red parking light input (-) grounded to chassis
yellow/black to controlling alarms ignition input – not
connected
white – parking light output (-) white/light green at headlight
switch with 330 ohm
(parking lights are working properly both by themselves and via the remote start. Blinking with lock and unlock)
2 pin door lock output harness
red – door lock connected single wire system with correct
resistor
green – door unlock output connected single wire system with correct resistor.
(door lock and unlock working properly with remote control)
the remote start is not working properly when i press the trunk button twice in 5 seconds. What happens is the parking lights flash 7 times.
Does it need to be programmed?
Do i have something wired incorrectly?
Is there something else that must be hooked up that isnt?
Thanks in advance.
14 pin main harness
brake switch
connected
switch with 330 ohm
resistor
Thanks in advance.
