Kapt
- Sep 23, 2015
- 1,023
- 305
- 2016
- 3L
I still have the original paper 6x9's in my 04 Ram standard cab. If I decide to swap them out for some aftermarket speakers, what do you all suggest replacing them with? I've never had the door panels off the truck, so I don't know what kind of space there is in there for aftermarket. Should I go with new 6x9's? Or should I switch to a component speaker setup?
What have you done? Got any pictures? If not, got any suggestions on what would work best?
Here's what I have now. Kenwood digital media player for a deck. Stock 6x9's in the doors with Lanzar 1" tweeters running off of them. In the back are the paper 6.5's (is that what came stock?). Behind them are a couple of boxes on either side of the cab with MTX 12's in them, powered by a 500 watt amp. It sounds pretty good, but I eventually want to make it sound better. I don't need it to have a ton of wattage, it's loud enough as it is
