Double Din Progress
S
Silverbullet08
Persona Non Grata
Question: Where is your remote wire hooked to? Do you have subs ON from the deck?
At any rate, I'm going to assume that the pics look good considering that my ISP is being rather ******** and I need to plant my boot in their ass in the morning.
remote is hooked up to the relay so the bypass will work
Yup make sure they are powered up on the unit, as mine were switched off back when I bought my unit, took me a min to fig it out, yes I found it in the destructions, looking good tho nick keep up the good work
ok ill check that tomorrow. right now the old radio had extensions that will reach the wires i have. now they are too short to reach all the way to the back of the headunit...
Looks good Nick. What head unit is that?
pioneer avh-3200dvd
So, what is your plan for the bezel?
gonna gorrilla glue plastic to cover the side openings. bondo it smooth and paint
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
That might be your problem. You do understand that the remote wire sends a low voltage signal to the amplifier telling it to turn on, right? If you have the remote connected to the wrong post on the relay, then it is not getting power sent through the line to it. Some, SOME amps are picky about how many volts it takes to accept a signal for the turn on loop, and if you're over it, then that could be another issue. Usually something like 5V IIRC.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
so.....what was the problem?
S
Silverbullet08
Persona Non Grata
aside from the input wires being too short i didnt connect the remote wire from the amp to the hu
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well that explains a lot. Looks great Nick. I am so jealous!!! I would love to fit a DD in my truck.
OklaHemi
new age hemi
get her done nick. cant wait to see the final result
S
Silverbullet08
Persona Non Grata
well i got the bondo today. and went to test fit the bezel. i didnt like how it lined up so i need to trim that up more. the dremel is at my dads and he was at work so i didnt get to do it today. i did get the dash in though. i have heat again lol
Oefootball_70
OLATHE
Deff making progress. Makes me jealous everytime I see a double din in a Dodge Ram 02-05
Trupiano
Registered User
6.7L CTD
Kick-ass man! What kind of double din did you get? You gonna fiberglass the bezel? I vote fiberglass it in, sand the whole thing, and paint it silver!
Edit: Nm didn't see this second page lol
The Assassin
B-more careful, Murderland
I'm curious as to why Metra or some other company hasn't made a double din kit for the 02-05's?
Also, how was the Bondo to work with? I have only ever worked with fiber glass.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Probably......because you have to cut up the stock bezel. Not just a "plug n play" deal.
I heard if you go to the dealer they have a gps bezel for the 04/05's. But I haven't verified this, and I think they said it was like $170.
Interesting.......
