Hi, I have a 2002 ram 1500 4.7 . i bought it not running, it wouldn't crank over and no dash lights.
i put power from battery to the yellow wire from ignition switch and it cranked over but no start.
then i put power to the IGNITION SWITCH OUTPUT (OFF-RUN-START) and the dash lights came on! so i jumped the yellow wire again and it started right up.
so i tried to put the blue IGNITION SWITCH OUTPUT wire on a switch but i accidetly put power to another power wire for the key in ignition sensor and it shorted. when it shorted it touch the ground wire 1 pin down on the plug and melted the ground wire under the dash. i de-pinned the melted wires and replace with used wires from another truck. then i put power from battery to the blue wire again and it ran but it died on me after 10min.
now it cranks with the ignition switch(fixed its self?) and dash lights work(hot wired) but it wont start the fuel pump isnt running. i took cover off the fuel pump relay and manually closed the relay and it ran the fuel pump but still no start. i think it could be the asd relay has tripped. please help
