General LED light bar questions
chedched
Madison, WI.
2019 Power Wagon
I want to add a light bar to my truck. I'm looking at installing it in the lower valance where tow hooks are mounted on some trucks. Questions:
1 - Curved or Straight? The idea of the curved one is pretty good but I want to know what everyone else has done and how it's turned out.
2 - Length? What lengths has everyone used?
3 - Heat? Do they generate much heat at all?
As always folks, pictures are much appreciated...
derekp
Buda, Tx
1990 5.9 Cummins
I did the same thing as him ^^
Never had a heat issue, just make sure it's wired up correctly with a relay and fuses.
chedched
chedched
Madison, WI.
2019 Power Wagon
Any other input? Really looking to order one soon.
chedched
chedched
Madison, WI.
2019 Power Wagon
He shows two albums, 1 for his 11 and 1 for his 14. His 14 has one mounted at the bottom of the front bumper. I'm looking to mount it where the tow hooks would go.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Oh, well you said valance which is in that area. Do you have tow hooks from the factory? My tow are different from the HD tow hooks as mine are more centered and the HD's are to the outside, I suspect you have the SLT bumper chrome/painted. With HD style hooks to the outside you should be able to get a 30" in there no problem.
chedched
chedched
Madison, WI.
2019 Power Wagon
I've got no hooks so that frees up the entire insert in the bumper. You are correct, I have the SLT chrome/painted bumper assembly.
I like the idea of mounting it below the bumper except when offroading. I want it protected as much as possible.
