Here's some updated pix. Today I got the amp rack mounted. You will also see the trim piece that I made that will be upholstered and will help make it look clean and complete.
The brackets mounted.
Where it goes
Installed!
Trim piece
Tomorrow will be a day of wiring. As you can see by the pictures, I've already got the amps grounded (look closely) so tomorrow I will run the RCA's to the head unit, run the remote to the head unit, mount and wire the fused distribution block, run all four door speakers and run the subs speaker wire down. Once I get all of that done, I'll put the headliner back in and begin installing the blue LED's and trim piece. Once the headliner is all done, I'll start the fiberglassing of the box!
