Help Sub not working!!
S
Silverbullet08
Persona Non Grata
ok just did some tests.
tested the fused in the engine. its fine not blown.
then wired another speaker (fromm my boom box lol) to the amp and it played. so the amp is good and is transfering power.
then we ran that speaker to the wires in the box and that worked. so the sub is getting power....
i think the problem is the wires from the terminal leading to the sub...
quietpeen
2021 TRX
Hellcat
sounds like you got it narrowed down...hopefully that is it. Would be an inexpensive fix for ya
S
Silverbullet08
Persona Non Grata
yea i was right. the + wire on the terminal came off... had to solder it together again.
I got my boom boom back!! :D thanks for the help guys!!
quietpeen
2021 TRX
Hellcat
SWEET!!! Once I had a problem where the sub would work real crappy then turn on and off, I thought I might have blown it because how bad it was sounding. Turned out the wires were loose at the sub. Tightened up the clips and it sounded great again.
