JamesRam
Hi everyone
So I ordered a couple of HID kits from eBay for my 08. My buddy put a set in his 03 and they seemed decent so I thought Id try them outt. When I got them I put them in and I remember the flicker issue. So I add two relays to each side to prevent the flicker, one for high one for low. I get everything wired up and working and then I put it all back together. I got out in my truck for five minutes and see that the passenger side light is out. High and low are connected the same and high still works but low doesn't. So I went through it all I have power everywhere but the ballast isn't working. So I swapped the ballast with one from the kit I ordered for my fog lights and it works. Put it all back together again and go out in my truck and it's out again. I know it's not a power issue or ground because high still works. The ballast just seems to burn out. What are the chances that I received two bad balasts? Any other suggestions one what my issue could be? Thanks
