Indicator Lights
Lugnutz
When I signal left (and only left) I will get 3 'blinks' of normal fashion and then on the 4th blink the indicator starts to go fast as if I had a burnt bulb somewhere - which is not the case. All lights on the truck are fine and operating but this has just started to happen. After about 10 seconds sometimes it goes back to blinking normally. Scanned for codes and nothing - replaced my TIPM about 2 months ago because of electrical issues. Any thoughts guys?
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
Check for a loose bulb, or bulb socket, also wiggle the wiring with the signal on to see if it changes. If you are using LED bulbs you may have a bad load resistor.
L
Lugnutz
Not using LED bulbs but I found a new piece to the puzzle today. It is the front drivers side light with the issue. All 4 indicator bulbs are illuminated on the truck but only 3 of them flash when they are supposed to. So when I signal left only the rear light blinks (fast) while the front remains solid. Fuse issue?
L
Lugnutz
Replaced the bulb and issues resolved.
