Thanks, I was worried there would be too much load on the LEDs.If you have fog lights already then you can just tap into the fog light wires but ground the leds to the truck frame. If you dont then yes, you will need a relay and a switch. The fog lights factory installed on a truck will have a fuse in the fuse box so if the load is too much it will blow the fuse. If it doesnt blow the fuse I wouldnt worry about it. The leds shouldnt pull too much power.
Also, this should be in the exterior section...mod help?
