Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Audio & Electronics
Audio & Electronics
Need help! Remote start
This is a discussion on Need help! Remote start within the Audio & Electronics forums, part of the 3rd Gen : 2002 - 2008 category!
So I got a remote start kit for Christmas it's a crime stopper rs4 G5 came with no install instructions ...
Reply
Old 12-26-2016, 04:20 PM   #1 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default Need help! Remote start
So I got a remote start kit for Christmas it's a crime stopper rs4 G5 came with no install instructions and idk where the wires go can anyone help me and show me where all the wires connect to so I could get this thing to work I'd appreciate it a lot thanks
Sponsored Ad
Register to remove this ad.
Mikeyn23 is offline   Reply With Quote
Old 12-26-2016, 04:59 PM   #2 (permalink)
justin13703's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
Here is install information for the remote start: http://www.crimestopper.com/cstech/l...ev_07-2014.pdf
And here is some wiring information for your truck. Scroll to post 6:
http://www.the12volt.com/installbay/....asp?tid=22042
justin13703 is offline   Reply With Quote
Old 12-26-2016, 05:15 PM   #3 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Yea I found the wire diagram I just don't know which wires go where cuz the instructions to the crime stopper are confusing
Old 12-26-2016, 05:40 PM   #4 (permalink)
Ram Year: 2008
Engine: Hemi 5.7
Default
Honestly there is a lot to installing those types of remote starts. It's not just a connect a few wires type of deal. You need to know how to use relays, resistors, and diodes to do this type of install.
Basically, if you find the directions confusing, you'd be better off letting a shop do it. I don't get into trying to walk people through a remote start install because they are very vehicle specific and require a lot of 12v electronics knowledge.
Old 12-26-2016, 07:47 PM   #5 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i would have to agree with Justin. if you don't know what your doing you are best to have a professional do it. they can be pretty complicated to install especially if you are not familiar with wiring or security systems. i know a lot of newer vehicles come from the factory with security systems and immobilizers as my mom found out 1 cold winter day. if you mess things up it could cause way more issues and cost you more than paying a professional to do it right the first time.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 12-26-2016, 08:39 PM   #6 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Yea I know what you mean I called around today and people want to much money to install it 400 500 bucks that's a little crazy to install it
Old 12-26-2016, 10:13 PM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
But the $400-500 also likely includes the bypass modules and everything needed to install a remote start in your specific vehicle. The more expensive the vehicle the more expensive the stuff is to install a remote start. There is more to getting a remote start than what is in the box at the store
__________________
Old 12-27-2016, 06:28 AM   #8 (permalink)
Ram Year: 2008
Engine: Hemi 5.7
Default
This is correct. If you have a chip in the key you will need an immobilizer bypass which is also a tricky install. 400 dollars to install the full system is normal. That's about what we charged to install them when I did installs. In a shop with all the right tools and equipment, and with trained professionals doing it, it will still take around 3-4 hours or more.
Old 01-03-2017, 09:58 AM   #9 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Yea I don't have th chip so I don't need the bypass module my brother has the same truck but different remote start I was gunna try and follow off his wires but his remote start has different color wires then the one I got has so I couldn't do that only thing his truck has is two relays for th door locks to work I was trying to see if anyone installed one before or could help me and show me what wires go where
Old 01-03-2017, 10:36 AM   #10 (permalink)
Ram Year: 2002
Engine: 5.9 Magnum
Default
I just finished an install (with immobilizer bypass) on my 02, and although I can't help you solve you're wiring dilemma, I will mention that unless you are absolutely positive you know how to wire and program a remote start system to your truck, I wouldn't recommend doing it. You only have one ignition harness and if you mess it up or tap into the wrong wires, you could be looking at higher costs simply to fix things. Not to mention the possibly risk of causing an electrical fire.
I'm not in any way doubting your ability to do this this though. I've just read enough horror stories from installs gone wrong and would hate to see try this and end up having issues.
argroft is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Remote start coolemoff1 4th Gen DIY 15 11-30-2016 10:34 PM
Remote start Hurley91 Audio & Electronics 5 11-26-2016 06:54 PM
wtb: remote start kit oem redrt_12 Audio & Electronics 2 11-11-2014 10:48 PM
Remote Start tkyle486 Audio & Electronics 17 11-12-2013 07:09 AM
remote start & wax job sullivan General Discussions 31 08-30-2011 09:55 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
