New and need help
KeysRam
Islamorada,Florida
4.7 Magnum
i want to put subs in my 2003 dodge ram 1500 quad cab but i dont know if i need a wireing harness and were to get a sub box for the back seat
KeysRam
KeysRam
Islamorada,Florida
4.7 Magnum
Yes everthing is stock when i bausgt the truck the guy gave me a Jenson Phase Linear UV8 but i dont really like the look of it
sullivan
Houston, Texas
The main thing you need to look at is where the subwoofers amp is getting signal. If you want to use the stock headunit, your going to have to use something like this:
Scosche LOC80 2-channel line output converter at Crutchfield.com
You would wire this device in line with a door speaker, ideally this installs an output for the subwoofers signal. From here you would install the rest.
If you install the Jenson headunit, it may have this output available on the back of the unit and you would not have to buy a output converter.
You may not like the look, but the functions and features are nice to have.
Let me know if you need any help. I installed my setup.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Welcome to the forum bud. Audio is not my strong point but theres alot of guys on here that can hook you up.
sullivan
Houston, Texas
As for the box, are you looking for a underseat enclosure? Or something that goes on top of the seats?
sullivan
Houston, Texas
There are good ones and cheap ones.
Cheap:
The best underseat enclosure is a foxbox. They have options for dual 10"s or dueal 12"s, or singles.
Check it out: http://www.foxacoustics.com/SearchResults.asp?Cat=40
These are the best enclosures, I am about to purchase one.
KeysRam
KeysRam
Islamorada,Florida
4.7 Magnum
Thanks guy i think i might start it i just need to make some more money hopefully in the next week thanks for everything ill put pics on when i start
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
do you want a single or dual? 12 or 10? Vented or Sealed?
I have a 10" vented Foxbox that is going up for sale VERY soon. :D
weedahoe
Banned
South GA
cammed and custom tuned 5.7
IMO, nothing better than a Foxbox. Put a double DIN head unit in there and it makes it even better.
