The brake and turn signals are working fine and are from the same wiring harness so I don't think it's a bad ground. Someone said it was a backup switch, but this is an automatic so not sure where this switch would be mounted.
On an automatic transmission? I knew there was on on a Manual Transmission but on an Automatic one as well? I read somewhere that it might be something called a transmission range sensor/tps assembly
