Question; I installed a double din in my 05,1500 and shortly after I started getting phantom codes pop up. I disconnected the radio and it stoped for a couple days then started back again. Whenever the code for example lamps out; none of the exterior lights will work or parking break code; it will engage my emergency break without the petal pressed. Have I damaged my PCM somehow?
