argroft
Ok, so I have a bit of an issue that I can't seem to figure out. The power locks on ink the driver's side door work at all as well as the power mirrors (both). The truck doesn't even know if the driver's side doors are open (no door ajar light/ dome lights). Now on to what happened before they stopped working: I installed a relay into the door and tapped into the red/yellow wire for power to trigger the relay. I assume the red/yellow wire was the +12v feed for the locks/ windows. At some point after tapping that wire, I lost power to it and thus my locks and mirrors. I cannot find a blown fuse and the instrument cluster shows a c-code of 64 00 (Driver door lock switch input circuit open). My best guess is that I blew something in the instrument cluster since it controls the locks.
Any help on what may have happened or what I can do to fix it would be greatly appreciated!
Sent from my SM-G935P using Tapatalk
