I dont have infinity I'm all alpine....but coming from the kicker manufacturing plant last week I am really impressed with the quality and sound they are putting out. I think you would be happy with them happier if you ran an amp..
@oddnoun you will not need a pry bar of any sorts for the interior for your dodge ram. You will be surprised at how far a phillips screwdriver will get you. You could use a 7mm socket instead if you prefer but the screwdriver will do the trick. Look at the little hook onthe lower right of the bezel, I have no idea what its for, a fast food sack maybe? On the inside there may be a screw there, if so remove it and then grab that lower right corner by said hook and pull straight out. It will pop then work your way around the bezel popping ot the sprinng retainers. Take your time when reinstalling to make sure everything is back in place. To me putting the screw back behind the hook is optional as I never have and have never had a problem. I belive there is a video on youtube that goes through the bezel removal but it is painfully slow and boring, maybe you could speed it up
