Tailgate light bar reverse wire
Alleya
Yup. White with Red. Hope your light lasts more than 5 months. Never seen one that actually works as designed. haha
You can also grab that same wire behind the tail light.
Hey man i carry a 49" and 60" bar with a lifetime warranty parking light, brake, signal left and right and reverse. Pm me if interested.. runs 120 shipped
fordtech90
Jonesboro, La 71251
Have any actual pics of them installed? Would like to see how noticeable they are
Alleya
Not on phone but I'll go grab one off my personal truck in a bit..
You looking to see how noticeable with lights off I assume?
fordtech90
Jonesboro, La 71251
Correct with lights off. Biggest reason I've never bought one cuz they look so tacky during the day.
Alleya
Yeah I hear ya .. ours don't look like a typical LED strip though to get a clean white had to use white LED chips which are in fact yellow.. there's a slightly smoked casing around ours sealing it from the elements and making it a bit less noticeable. I'll post pics shortly
Alleya
b6e806c0d7ea0167c367b82e21750290.jpg81d63ef5cd93647175b232de58ccb7e1.jpg296ab6844ae7cab6d2ff3f51323d458d.jpg
On the dodges there's a oem grommet in the way of one of the bars mounting pads with heavy duty 3m
In order to sit flush you can either remove the one mounting pad or pop out the plastic grommet like I did on mine.. takes all of 2 seconds
Has a nice solid piece of aluminum back plate and ships as one straight tube not all rolled up into a little box
Let me know what ya think
Alleya
Much better than the rest I've seen.
Very much appreciate that! Let me know if I could interest you in one.. pm for early Black Friday deal :)
Lil_Ram
Power tech 3.7L
Which color wire is it for the tail lights I've had my reverse wire not hooked up since I bought mine in like may and need to do it.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
It's the white wire with red stripe. Should be middle wire of the 7 pin lighting harness/connector.
Lil_Ram
Power tech 3.7L
I asked for the tail lights not the 7pin since I have a 4 pin
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I like this, have any pics at night to show reverse lights?
:naughty:
12sportmc
NC
:naughty:
Would also like to see a night shot with reverse and turn signals[emoji106]
fordtech90
Jonesboro, La 71251
You will have to tap into both the white/brown tracer and white/dark green tracer, doing so will give you tail lights and blinkers.
EDIT: you will also need to add a diode to each circuit to ensure no voltage returns to opposite side. Example- w/o diode and you hit right blinker, left blinker will also engage since you are tying circuits together and flow goes to ground. Add a diode and power can not "flow uphill" so to speak.
fordtech90
Jonesboro, La 71251
So I got one of these lights for Christmas. My wife surprised me with it. Got it installed today and looks great. However she ordered a 60 and they shipped 49. Actually didn't notice it until after I wired it up and was bout to mount it.
Alleya
Hey sorry to hear ya got the wrong one.. pm me your order number and I'll be happy to see what I can do for ya
Avurado
