Windshield wiper fluid not working
chrisp2493
Always Modding
Warren, OH
392 Hemi
So I've had a problem since I've bought the truck a year ago, and haven't figured it out yet. The windshield wiper fluid won't spray on the turn signal stock. Everything else on the stock works, wipers function, turn signals, etc...just no wiper fluid. If I press the spray button, the wipers activate, but no spray. I can't find any fuse that's related to the wiper motor anywhere. The previous owner must not have figured it out, because they ran a hot wire to a little push switch on the steering column, all the way out to the wiper motor itself. So if I push that switch, it will spray. So I do know that the washer fluid motor is working, just no power coming from the stock. Any ideas? I'm probably gonna try buying a replacement turn signal stock, just looking any fuses or wiring to check
David Jones
Alabama
HEMI 5.7
I have the same issue (without the work around).
2014 RAM 1500
HemiLonestar
MD
Generally something screwed up in your multifunction switch (or the plug to it)
