wire identification help
IJW84
I am changing the front door speakers in my truck ('08 1500) and need to know which wires are + and -
both the wires are green, one has a blue strip and the other is a yellow strip.
nothing else in the old speakers indicates which is which.
thx
Bullitt5339
St Pauls, NC
LF Speaker +: Dark Green/Yellow
LF Speaker -: Dark Green/Light Blue
RF Speaker +: Gray/yellow
RF Speaker -: Gray/Light Blue
LR Speaker +: Gray/Light Green
LR Speaker -: Gray/Dark Green
RR Speaker +: Dark Green/Light Green
RR Speaker -: Dark Green/Gray
IJW84
IJW84
right on...thank u very much
justin13703
MD
Keep in mind that you can buy plug in speaker harnesses for around 12 dollars for all 4 that will keep you from having to cut/splice the factory wiring. They also help prevent corrosion on the cut/spliced area of the wire over years in the environment of the inside of a door panel.
