CostaRam
HI!
I cam back to Costa Rica and my 2011 Ram 1500 trows the following codes:
C1027 (Left Rear Wheel Speed Sensor Signal Erratic Performance)
U1417 (implausibel left wheel distance signal received)
This is another problem and i probably need to swap the sensor
P0131 - P0137 - P0151 - P0157
This 4 codes above are problems with the O2 Sensor Heating Element,
ans as far i found out, this can be a blown fuse for the O2 Heater Element.
Unfortunately i am not able to identify the correct fuse as the manual only show the blade fuses,
Does someine know what is the fuse number or fuse position so that i can check that?
Thanks so much!
Chris
UPDATE:
I pulled all the fuses in the fuse box and checked them: all good
The various lamps showing ABS, ESP and Check 4WD went off while driving for 10 minutes on paved road.
I stopped to get some food and when i left car started to behave strange as always when driving backwards and on gravel or turning hard when this error shows up.
- "Grinding" noise from left front side (probably the ABS pump)
- car rocks while driving backwards (probably ABS who brakes without reason, similar as driving on sand)
- Instrument cluster goes crazy, needles move up and down, center display scrolls, goes on and off, several alarm signs go on and off
After finishing driving backwards abs, service 4x4 and no ESP lamp come on
ut this is anoter story and probably left rear wheel speed sensor bad
Thanks so much!
Chris
UPDATE:
