Well if it is turning over, then the start circuit is fine, it is the ignition circuit you have issue with and that would take some diagnotics troubleshooting to find.
Could be a PCM, Crankshaft position sensor, Camshaft position sensor or associated wiring. A tech is going to need to see what is work to figure out what is not working to narrow it down.
