Clearjab
- Mar 5, 2016
- 24
- 4
- 2009 laramie crew cab
- 5.7 Hemi
First of all Im new to posting on this forum but Ive been lurking around for some time... secondly forgive for my bad grammar, english is not my native lenguage... recently Ive acquired a 2009 ram 2500 laramie crew cab in relative new condition ( about 1800 miles on the clock) as part of a collateral on some bad buisness... however it has some small issues that I want to fix since Im thinking on keeping it since Ive been using it for this past weeks and I really like it, its better than my f150, if you guys can help me in any way I would appreciate it.
1. Dual zone A/C is acting weird... for example it has the recirculation bled door actuator problem and I know that I will have to take the entire dash apart but theres anothe issue, when I start the truck it takes a while for the fan speed knob to work... it starts at the lowest speed and no matter what speed you select it wont go faster for at least 5 to 10 min then it works normal... what could it be since the ac controls are a single module?
2. it was equipped with remote start but it seems to be missing the hood pin and wire harness cause I cant find it for the life of me and when I want to use it evic displays remote start aborted hood ajar... if some one has a picture of it or were its supposed to be would be great if not, would it be possible to use a 2010 hood latch sensor and adapt the harnes?
3. dumb question probably it comes with dual headlights Im planning on swapping them for the 13+ projector headlight and Im aware of retroshop harness but every swapp Ive seen are from quads to projector my question is if the headlight harness is the same for the duals and quads or should I buy another one for quads or does the retroshop one works for quads and duals alike?
