2011 Ram 1500 r134a pressures
PSYS
ARIZONA
2011 RAM SPORT REG CAB 4X4
5.7L HEMI
I've scoured the internet (and this forum). Perhaps the wildcard search isn't giving me the most accurate results. I'm wondering if anyone has a maintenance manual on a 2011 Ram 1500 5.7L (4th gen) in regards to the r134a pressures (suction/discharge).
I did a search and am unable to find anything. I'm guessing this question has come up at least a few times in the past. Does anyone have this information they would be willing to share? I'd certainly appreciate it if you could!
Fergusontd
FTD
Villanova
Get an a/c gauge and you can measure the pressure at the fill valve under the hood. It will yell you if you need any 134a. ftd
Tach_tech
5.7L HEMI
Standard R134a pressures. Just pressure wont tell you if it's low though, only way to know for sure is to have it discharged with an A/C machine to weigh the refrigerant.
scott lass 18
rocklin ca
2010 ram 1500
mine was bad day one i charge it and over a year do it again had to put a stop leak in in charge it again good now three years !
