Im looking for a wiring diagram for the LED in overhead console that shines down in center console. Mine is not working I checked light found no power to it and all fuses are good. Anyone know where the power is from? All other lights are working but this one.I know its a little issue but it would come in handy when working nights. I bought truck used and it hasnt worked as long as I have owned it 1 month
Thanks
Walter
Power originates at Fuse 14 in the Power Distribution Center, which pretty much powers all interior lighting.
LAMP-CUPHOLDER-FRONT
Harness Family: Headliner_RT
Cavities: 7
Color: BLACK
Gender: FEMALE
Part Description: 7123832830
Engineering Name: OHC_LAMP_LED
Connector No: D2326A
Option: Standard
Pin Circuit Wire Color Gauge/Size Function
A Z905 BK 0.5 GROUND
A Z905 BK 0.8 GROUND
B M5 WT/LG 0.8 FOOTWELL LAMP FEED FT LT
Interior Lighting - Operation
OPERATION
The lamps of the interior lighting system can be divided into general classifications based upon the circuit that controls their operation: The courtesy lamp circuit, the reading lamps circuit and the panel lamps dimmer circuit. The center bezel lamp is actually controlled by a park lamps output of the Body Control Module (BCM) (also known as the Common Body Controller/CBC), which energizes this circuit at a fixed intensity whenever the exterior lighting is illuminated.
Following are paragraphs that briefly describe the operation of the courtesy lamps, reading lamps and panel lamps dimmer interior lighting circuits. The optional rechargeable flashlight,
the cup holder lamp and the automatic transmission gear selector lamp are controlled by an output from the BCM, which energizes these circuits whenever it detects that the engine is running.
The lamps and the hard wired circuits between components related to the interior lighting system may be diagnosed using conventional diagnostic tools and procedures. Refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, details of wire harness routing and retention, connector pin-out information and location views for the various wire harness connectors, splices and grounds.
However, conventional diagnostic methods will not prove conclusive in the diagnosis of the interior lighting system or the electronic controls or communication between modules and other devices that provide some features of the interior lighting system. The most reliable, efficient, and accurate means to diagnose the interior lighting system or the electronic controls and communication related to interior lighting system operation requires the use of a diagnostic scan tool. Refer to the appropriate diagnostic information.
