Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Tech Info
4th Gen Technical Service Bulletins
This is a discussion on 4th Gen Technical Service Bulletins within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. ...
Closed Thread
Old 11-08-2010, 03:14 PM   #1 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default 4th Gen Technical Service Bulletins
Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. TSB's are registered with the US Government and below is an export of that data.
To search for TSB's for your specific Year / Model please see: ODI - Office of Defects Investigation
The included information does not have step by step "how-to" or part numbers. It is simply a notification that there was a problem with a specific component.
TSB's are performed by Dodge dealerships for no cost if the component is still covered under warranty. For the most part if your vehicle is outside the bumper-to-bumper warranty the service will be billable. Some individual components have an extended service warranty due to a specific failure. Speak with your local Dodge service representative to check the status of your vehicle.
The "SERVICE BULLETIN #" or "REPLACEMENT SB#" numbers provided are provided by Dodge and should be searchable by your Dodge service representative.
Sponsored Ad
Register to remove this ad.
__________________
Owner & Service Manuals for many years: www.scribd.com/lilfroger/shelf
lilfroger is offline
Old 11-08-2010, 03:32 PM   #2 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb csn-k17: Hvac mode door actuator gears
Service bulletin #: Csn-k17
replacement sb#:
Nhtsa item #: 10034072
date: 20100901
failing component: 118000 electrical system: Software
make: Dodge
model: 1500, 2500, 3500
year: 2009, 2010
date created: 20101015
description of summary: Dodge: Reprogram hvac control head and inspect/replace actuators. The hvac mode door actuator gears on vehicles may break and result in the inability to fully control the hvac functions. Csc letter was rec'd. *pe
__________________
Old 11-08-2010, 03:33 PM   #3 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb csn-k20: Engine water pump leak
Service bulletin #: Csn-k20
replacement sb#:
Nhtsa item #: 10034071
date: 20100901
failing component: 062000 engine and engine cooling:cooling system
make: Dodge
model: Ram
year: 2010
description of summary: Ram/dodge/jeep: The engine water pump on certain vehicles may leak coolant. Engine operation with a low coolant level could cause engine damage or low cabin heater output. Csc letter was rec'd. *pe
__________________
Old 11-08-2010, 03:34 PM   #4 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb sb-19-004-10: Steering wander
Service bulletin #: Sb-19-004-10
replacement sb#:
Nhtsa item #: 10033731
date: 20100529
failing component: 014100 steering:rack and pinioninion shaft
make: Dodge
model: 1500, 2500
year: 2009
date created: 20100915
description of summary: Dodge: Steering wander. While traveling on a straight stretch of highway, customer may feel the need to provide steering input to correct a vehicle wander condition. *pe
__________________
Old 11-08-2010, 03:36 PM   #5 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb sb-18-003-10: Short runner valve
Service bulletin #: Sb-18-003-10
replacement sb#:
Nhtsa item #: 10033690
date: 20100115
failing component: 114000 electrical system:wiring
make: Dodge
year: 2009
date created: 20100910
description of summary: Dodge: Bulletin involves replacing the short runner valve (srv), srv connector, wiring pigtail, and adding a new stud for a tie strap. *pe
__________________
Old 11-08-2010, 03:37 PM   #6 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb sb-19-002-10: Steering wander
Service bulletin #: Sb-19-002-10
replacement sb#:
Nhtsa item #: 10033671
date: 20100123
failing component: 010000 steering
make: Dodge
model: 4500, 5500
year: 2009
date created: 20100903
description of summary: Dodge: Steering wander. Involves selecting the proper repair procedure based upon vehicle build dates and then aligning the vehicle with revised specs. *pe
__________________
Old 11-08-2010, 03:43 PM   #7 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb sb-14-001-10: Ctd electronic fuel control actuator
Service bulletin #: Sb-14-001-10
replacement sb#:
Nhtsa item #: 10033546
date: 20100202
failing component: 061200 engine and engine cooling:engine:diesel
092100 fuel system, other:delivery:fuel pump
make: Dodge
model: Ram
year: 2009
date created: 20100823
description of summary: DODGE: ELECTRONIC FUEL CONTROL ACTUATOR (FCA) AVAILABLE FOR SERVICE/NEW DIAGNOSTICS AVAILABLE FOR DTC P0251. ENGINE SURGES AT IDLE OR MIL ILLUMINATION. FURTHER INVESTIGATION MAY IDENTIFY DTC P0251-CP3 PUMP REGULATOR CONTROL-DIESEL. IF P0251 IS PRESENT, FOLLOW THE DIAGNOSTICS IN THIS SB. IF OTHER DTC'S ARE PRESENT, REPAIR AS NECESSARY BEFORE PROCEEDING FURTHER. MODEL RAM TRUCK. *PE
__________________
Old 11-08-2010, 03:46 PM   #8 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb sb-09-050: Improved fuel tank venting
Service bulletin #: Sb-09-050
replacement sb#:
Nhtsa item #: 10033185
date: 20090825
failing component: 071100 fuel system, gasoline:storage:tank assembly
make: Dodge
model: 3500, 4500, 5500
year: 2009
date created: 20100723
description of summary: Dodge: Improved fuel tank venting. Vehicles were shipped with a fuel tank vent that under severe conditions, may allow moisture and debris to enter the fuel tank through the vent. Dealers are requested to replace the fuel tank vent with a revised part. *pe
__________________
Old 11-08-2010, 03:53 PM   #9 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb dr-j-35: Ctd heavy sooting
Service bulletin #: Dr-j-35
replacement sb#:
Nhtsa item #: 10033113
date: 20100401
failing component: 063130 engine and engine cooling:exhaust system:emission control:gas recirculation valve (egr valve)
061000 engine and engine cooling:engine
make: Dodge
model: 2500, 3500
year: 2009
date created: 20100708
description of summary: DODGE: ENGINE CONTROL MODULE (ECM) SOFTWARE PROGRAM ON ABOUT 159,700 TRUCKS MAY CAUSE ILLUMINATION OF THE MALFUNCTION INDICATOR LAMP (MIL) WHEN NO PROBLEM EXISTS OR UNDER CERTAIN CONDITIONS ALLOW HEAVY SOOTING OF THE TURBOCHARGER, EXHAUST GAS RECIRCULATION VALVE AND DIESEL PARTICULATE FILTER. HEAVY SOOTING COULD DAMAGE EMISSIONS COMPONENTS AND RESULT IN INCREASED EMISSIONS. THE ENGINE CONTROL MODULE MUST BE REPROGRAMMED (FLASHED). CSC LETTER WAS REC'D. *PE
__________________
Old 11-08-2010, 03:56 PM   #10 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default TSB ER-J-22: Rear Axle Ratio
Service bulletin #: Er-j-22
replacement sb#:
Nhtsa item #: 10033107
date: 20100301
failing component: 106000 power train:axle assembly
make: Dodge
model: 2500
year: 2009
description of summary: Dodge: The axle(s) on about 160 certain ram truck vehicles were inadvertently built with a 4.10 axle ratio. This is a non compliant powertrain configuration and could impact the vehicle's fuel economy and/or performance. The axle ring and pinion(s) must be replaced with 3.73 axle ratio ring and pinion(s). The tipm must also be reprogrammed for the new axle ratio. Csc letter was received. *pe
__________________
Closed Thread
Bookmarks
Tags
dodge ram tsb, dodge trucks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd Gen Service Manual Bigtman07 2nd Gen DIY 1 05-24-2011 02:30 PM
2003 Ram Service Manual Bigtman07 Tech Info 11 10-22-2010 05:05 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
