Bronco628
I am new to driving automatics. I do miss my stick shift. I have researched what people are saying and a couple said it normal. ?
When putting my truck into reverse from any position ( Park, neutral, drive) it sounds like to spline that are not rotating at the same speed and skip. After a second it clicks. No other gear makes this noise.
I checked the dipstick after driving it around a bit and then letting set for 20 minutes. It seemed to be above the full line for the hot side. I cleaned and checked multiple times with the same result.
Last month after I bought the truck and they found a small leak where the shifter goes into the housing. But this is the first time I remember hearing that sound.
Is this normal or should dodge dealer be looking into this. I got 4000 left on my 36000. I know powertrain is longer but I dont want problems later on.
