Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Tech Info
All lights on mod
This is a discussion on All lights on mod within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Originally Posted by OnSale I don't know about the hid's but I know with the led's they come with Drivers ...
Like Tree8Likes
Reply
Old 01-07-2017, 07:03 PM   #11 (permalink)
BBRAM2500's Avatar
Ram Year: 2016
Engine: 6.7
Default
Originally Posted by OnSale View Post
I don't know about the hid's but I know with the led's they come with Drivers and capacitors for our Rams and you just plug them in and that's it. Nothing else to it. There are tons of members on these forums that run led bulbs in their fog lights and hid's in their headlights and I've never heard of them having any issues.
And yes they sell yellow led bulbs. You can choose your color Tempature just like you would with an hid.
Sent from hell via TapATalk
To reply to how to have all lights on all the time the easiest way in my mind is to wire a relay to the low beam as it is on all the time (except when driving lights are on) and power your hid fogs off it. a digital ballast will draw between 35w and 55w so a massive relay is not needed. that is how i would and have done it then get a resistor to plug into the old can bus harness to not get a message
Sponsored Ad
Register to remove this ad.
BBRAM2500 is offline   Reply With Quote
Old 01-07-2017, 07:11 PM   #12 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default
When I had LEDs in my fogs and HIDs in the projectors there was no issue with bulb out messages or current draw. When I switched the fogs to HIDs all I added was a CANBUS adapter. Again no bulb errors when run alone or with the low beams at the same time.
mpress2570 likes this.
__________________
2014 Flame Red CC Express 4WD Hemi
MODS: S&B CAI, Flowmaster 50, Resonators deleted with 5" MBRP Black tips, Katskins, 8.4 MOD, 2.5 TGC level with Zone Auto UCAs, Weathertechs, Sport Style projectors with drop in HIDs, Retro'd fogs with matchbox projectors, OEM LED tail smoked out......more to come
12sportmc is offline   Reply With Quote
Old 01-07-2017, 08:24 PM   #13 (permalink)
mpress2570's Avatar
Ram Year: 2017
Engine: 5.7
Default
Don't you need canbus for leds too?
mpress2570 is offline   Reply With Quote
Old 01-07-2017, 08:29 PM   #14 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default
For the fogs generally no. They will have the resistors built right in. An example of this would be the Diode Dynamic XLM2s. For the high and low beams it depends on the brand used whether the capacitors will be built in or if you will need to run an additional resistor or CANBUS adapter. The 09-14 trucks are generally a lot easier to mess with on the lights because the CANBUS system wasn't as sensitive as the 15+ Rams. For any HID a CANBUS adapter or relay harness is required. Hope this helps
__________________
Old 01-07-2017, 08:55 PM   #15 (permalink)
mpress2570's Avatar
Ram Year: 2017
Engine: 5.7
Default
Yeah that's some helpful information. So say I just want to get HID what all do I need. For my charger all I have is 35w canbus ballasts. I want 55w for the truck. If I have canbus ballasts do I still need the warning canceler? I'm going to get the relay harness because I don't want to run too much power through my light harnesses and screw something up but here's what I have selected for heads and fogs (note it'll be a 2017)
Also what is the best brands to look into. I got my kit for my charger off of these guys and I've had them for over 2years and no bulbs have gone out yet.
Old 01-07-2017, 09:06 PM   #16 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default All lights on mod
You will need to run the relay harness on the 17 model. It's way more sensitive then my 14. I ran Morimotos on my 12 and now on my 14 and have had zero issues with them. Quality is top notch. Other people are running DDM kits and seem to like them. They are a lot cheaper. I just stuck to what I knew worked on my 12 for my 14. Have you looked into getting your stuff from Retroshop? Here's a link. Better product and excellent customer service. http://shop.retroshop.us/
Call Jeremy on Monday and he'll get you taken care of.
__________________
Old 01-07-2017, 09:09 PM   #17 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Also on your fogs you would want to add projectors to get the most out of the HID. They don't work very well in a stock fog housing The pic I posted is 35w 5k bulbs in the Morimoto matchbox projector
__________________
Old 01-07-2017, 09:26 PM   #18 (permalink)
mpress2570's Avatar
Ram Year: 2017
Engine: 5.7
Default
I looked into the morimoto system and I like what I'm seeing but now I'm confused by the purchase options. There are so many bulb sizes for the 2015+. I'm pretty sure I will need both 9005 for lows and fogs. I'm not sure though. But the truck I'm getting does have the factory projectors.
Also I don't see any options for canbus or capacitors just the mopar harness. This site has confused me haha. Sorry to keep bothering you I'm just trying to figure this all out so I know exactly what I need to buy.
Old 01-07-2017, 09:28 PM   #19 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
LED Bulbs usually come with the following:
▪Bulbs:
▪Drivers:
▪Capacitors:
Look at it like this. If you compare an LED Kit to an HID Kit, the LED Drivers are pretty much the "ballasts" if you want to call them that. The Capacitors are pretty much the "error free Canbus adapters".
Everything is smaller and easier with the LED Kit. The HID Kit is more complex and "harder" to install if your a novice.
It really just comes down to preference. I had the Opt-7 Boltzen Bi-Xenon 35w 6000K CanBUS HID Kit Relay Capacitor Bundle on my 2006 Ram 1500. The kit was a nightmare to install, wires had to be cut and switched on the relay plug that connected to the trucks H13 plug. It was horrible. Then half the time the lights wouldn't turn on, I'd have to flip the headlight switch off and back on again. They took a long time to warm up and the lighting actually sucked big time.
Now I have the Opt-7 FluxBeam-X 6000K H11 LED Kit in my 2012 Ram 1500 and the output is amazing. They are 10x brighter than the 6K HID bulbs I had in my 06. There is no delay in brightness when you first turn them on, I dont have any "dead spots" or "black areas" in the light beam pattern that some people get with hid's and led's.
In the end, in my personal opinion, the LED kit was 1,000x easier to install. It only took about 25 minutes from loosening the first bolt to tightening the last bolt. All I had to do was remove the old bulb, connect wires labeled #1 to #1, 2 to 2 and 3 to 3. Then I tucked it all into the housing and closed it up. But with the HID kit it took over 3 hours to figure it all out, run the wires, install it all. I had to drill holes to mount the ballasts, cut and extend wires, cut and switch wires etc. Alot of trial and error. The LED Kit wins, hands down, when it comes to ease and time of installation.
As for light output, again, in my personal opinion, the LED kit was 10x brighter then the HID kit. The light from the LED bulbs isn't scattered all over. It's more centered and crisp. You can see a clean & clear cut off line with the LED bulbs in a halogen housing that you wouldn't see with HID's unless you have projectors.
Either way, both are a better option over stock Halogen bulbs. Like I said multiple times, it all comes down to personal preference. Do you want to spend the time hooking up the HID kit or do you want an easy install with the LED kit? Either way you end up with 6000k bulbs that are better then the horrible stock halogens.
__________________
12' RAM 1500 RCSB ST - K&N 63 Series - Flowmasters Dual Exhaust - Black Chrome Clads - Lund Tri-Fold Tonneau - Phillips CrystalVision 9145 Fogs - Clazzio Custom Black Leather - OEM 1500 Fender Flares - 20% Tint All Around + more...
OnSale is offline   Reply With Quote
Old 01-07-2017, 09:30 PM   #20 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default
No bother man. That's what the forum is for. It will be easier for you to select all your options here: https://shop.retroshop.us/ProductDet...4G%2E15%2EHIDs
Then you can either purchase from Jeremy or go back to the morimoto site.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bed lights, puddle lights, flush mount reverse light install (PIC heavy) sbarron Exterior 115 12-01-2016 05:05 PM
Geno's Garage May Special - Save 10% on Headlights, Tail Lights and Fog Lights Geno's Garage Geno's Garage 0 05-01-2015 12:52 PM
tying fog lights into running lights or tail lights *tim* Exterior 0 11-22-2014 09:15 AM
head lights/blinkers/brights/break lights not working!!! tsmith92 Audio & Electronics 2 07-13-2013 04:47 PM
will the 2011 ram head lights plug in the quad lights xariver Exterior 6 05-01-2013 03:58 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
