Any Dodge techs on here or some one with a 2011 service manual?
1500ram12
5.9L Cummins
thats the tpms. This is what I found I pulled the light grey/natural color connector. im just waiting for my kit to come in so I can install it and hopefully it fires right up. I already have the switch and have the sales code installed. I was going one route with lighting then changed my mind.
top view
back side of plug. notice the white plastic sticks, they are in place of the fog wires and what ever else goes to this plug
roadrnnr
roadrnnr
Vermont
top view
You put those sticks in right? Mine has wires in the 11/16 slots now. Mine also has more wires in there than yours but I have a slt.
Were there any wires in slots 11 and 16 in your plug?
Also how did that come apart?
Are you saying that pix I sent you of the module is the TPMS module?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
whats different? I know the rear ends are.......but I'd bet that a great chunk of this is the same? just curious on what they changed on these things. lol
roadrnnr
roadrnnr
Vermont
I am looking for the wiring diagrams for my 2011. They changed everything in the fuse box in 2011. am now finding out there seems to be even more than one configuration between models.
It would come in Handy for other things non electrical though. def good resource to have on hand.
1500ram12
5.9L Cummins
if you have wires in 11 and 16 you must have the fog light wires somewhere up front. the white sticks where their. the pic you posted was the tpms I have the same thing on the drivers side. I'd do some poking around underneath the front end they must be there somewhere. it just had a red slider that pulled out or in (dont remember now) than you pushed down on the clip and it pulled out. I believe this connector is right behind the green connector. The connector is c4
roadrnnr
roadrnnr
Vermont
Nope no plugs up front anywhere. I checked and double checked.
The other guy with the 2011 had wires in his 11/16 slots also. he just pulled them out an replaced them with the wires from the mopar kit and his worked.
Still am curious what those wires go to. That is why I wish I could find the wiring diagram somehwere but no 2011 manuals anywhere to be found.
Let me know if your works when you plug those wires in there.
Oh yeah I know how to get it loose from the fuse box by releasing the red slider but I am wondering how you get it apart to put the wires in the slot?
1500ram12
5.9L Cummins
that is weird, If you do that just make sure everything still works afterward. the link that was posted earlier that went to the chrysler site is the one I'm using and so far it seems to match up for 2012. 2011 seems to be the same according to that site. I wont know until I get the lights. let me know how it turns out
1500ram12
5.9L Cummins
I got the wiring harness installed took about 5 min. all that is needed to be done once you have the c4 connection in your hand is pry up on the face of the connector and it will pop up the slide the 2 wires from the harness in 11/16 put everything back together. If you already have the switch and sales code installed you're all but done. I didn't end up using the fogs with the kit I bought some hella mini FF. It took about an hour to get them mounting with a little of persuasion to bend some of the factory brackets down a bit. Here's a pic of the lights.
roadrnnr
roadrnnr
Vermont
Finally got em working today at the dealer. Mopar needs to update their instructions for 2011 and 2012's
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
Where did you get these foglights? I you have a part number?
That is all.
1500ram12
5.9L Cummins
I got this kit off of ebay from steve white automotive or dealership. It's a dodge dealership . the part number is 82211694AB
1500ram12
5.9L Cummins
Come to think of it I never used the fogs I added in hella micro FF lights but used the wiring from the kit. As far as I know you don't need to modify anything to get the fogs to fit. I've since added added a factory front bumper with fogs
Sent from DROID RAZR MAXX using Tapatalk
fyrftr422
I had read somewhere that the 2011 had wires (both black???) in the #11 and #16 slots as you found out, but that they were dead and could be taken out and taped-up. My 2012 had those 2 white wire plugs in them, like the earlier pics showed, which were easily removed and the proper fog light wires installed. Now to get the system flashed so they work. I decided to stick with the factory ones since I also installed the factory tow hooks, which go in the location you installed your mini fogs.
fyrftr422
I'm almost afraid to ask since I've read some outrageous amounts by some dealers charging for this simple 'flash'. What did they charge you to install that sales code? It is all I have to do to have them working (and I could get 2 things done, have my newly installed trailer brake controller flashed at the same time)
1500ram12
5.9L Cummins
All depends upon your relationship with the dealership. Mine was free
1Popeye
