I have a 2010 Ram with a 5.7 Hemi. Today The check engine light came on and the MDS won't engage. I was wondering if there was a way to check the fault codes like there is in older models by cycling the key.
Thanks
Thanks
Should be the same key trick, turn the key from off to on like 3 times I believe?
