Check Fuel Cap
Workram11
Hemi5.7
My "check fuel cap" message just came on this morning. Cap looks fine, what else could cause this message to appear?
Sent from my iPhone 5 using Tapatalk
audio1der
Airdrie, Alberta
I'd try a new cap; they're not expensive to replace. A bit surprising it only lasted that long but they can lose their seal/go bad.
dogcar3
2012 Power Wagon
Get a locking one. First thing I did to my truck.
W
Workram11
Hemi5.7
Ill get one when I get into town and see if that does the trick.
02Steve15
Connecticut
Sometimes they just need to be replaced after a while. I've had that issue a couple times.
W
Workram11
Hemi5.7
I wonder if putting a new o ring would also do the trick
Cthulhu
Calgary, AB
Cummins 5.9
You have a return line that bypasses the fill line to allow air to escape.. there's rubber fittings around that. On my 07 Hemi I had they failed less than 2 years into the lease.. Put the 'asscap' message in the odometer screen.
Rotzilla
colorado
6.7 CTD
Mine came on the other day, totally forgot about but noticed driving home that it had gone off. Has not come back on sense. ????
HemiBabe
DFW
Mine keeps doin it too
[tapatalkin]
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Could also be the Leak Detection Pump when it goes bad the same light comes on and it happens when the little diaphragm in the LDP dries out and cracks.
$miley
ram-head
Arkansas
This code was a problem with 3rd gens. Mine did it. Tried an aftermarket cap. An OEM cap. Had the tank and filler hose checked checked by two different mechanics. Never figured it out. I put around 40,000 miles on it with it coming on randomly. I finally even quit clearing the code because it just came right back.
W
Workram11
Hemi5.7
It stopped coming on before I got into town so Ill let it be for now
mmcquinn
