computer messages
09SMOKINHEMI
TEXAS
How do I reset the system on my Ram everytime I do an oil change? I recently changed my oil/filter, and now the message popped up saying that I need to do an oil change. not sure what the secret code is to reset it.
Musclemckeester
Houston, TX
n/a
n/a
1) Turn the ignition switch to the On/Run position (do not start engine).
2) Fully depress the accelerator pedal 3 times within 10 seconds.
3) Turn the ignition switch to the Off/Lock position.
Note: If the indicator message illuminates when you start the truck, the oil change indicator system did not reset. If necessary, repeat this procedure.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
awesome! thanks guys. the dealer probably would've shafted me :)
