Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Tech Info
Convert to LEDs!!!
This is a discussion on Convert to LEDs!!! within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Started working on creating an ALL Generation LED bulb guide. Also we will include HIDs to make everyones life a ...
Like Tree17Likes
  • 17 Post By MADDOG
Closed Thread
Old 05-25-2012, 10:55 PM   #1 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Post Convert to LEDs!!!
Started working on creating an ALL Generation LED bulb guide. Also we will include HIDs to make everyones life a little easier. If you have read through a bulb replacement guide you will notice that most of the LEDs bulb # is the same as the halogen bulb number say from PepBoys or Autozone.
Here is a good link also to try and figure out what sort of bulbs you need for ANY vehicle. They way they create their list can be slightly confusing though, Superbright LEDs.
A little more on reading into LEDs as well reveals that most suppliers label their LEDs the same way. We will use the most popular "921" bulb
The p/n for a blue 921 as seen in the pictures below is, 921-B12:
921 <--refers to the bulb type B <-- refers to the color 12 <-- refers to the amount of LEDs in the bulb
another example would be a red version for the third brake light which would read:
921-R12
Also remember LEDs are polarized, meaning they will only work one way. If you plug your brand new LED in and it doesn't work, pull it out and insert it the other way before making an angry phone call to the supplier!
4th Gen LEDs
Reverse - 921
Cargo Lights/Top mount break light - 921
Map lights - 921
Dome light - 4410
License plate - 194
Tail lights / Brake lights- 3157
Front turn signal / Side marker - 3157
4th Gen HIDs
Quad lights
High beams - 9005/HB3
Low beams - H11
Dual lights
High/Low - H13/9008
Fog lights
(regardless of headlights)
H10/9145/9140
THIRD GEN LEDS
Reverse - 3rd Gens from 02-06 use 3057/3157, 07-08 use 921
Third Brake Light-921
Dome Light/Map Lights-578/212-2 (I found one that is MUCH brighter that fits both festoon style map lights and the dome light, it is a 4210-HP6 bulb, I used 'cool white', so as described above a '4210-CWHP6' bulb. It's like daylight in the cab.)
*Note* Some trucks also have the map light bulb listed as a 194.*
License Plate-168
Tail Lights/Brake Lights-3157 *Use a RED bulb for this*
Front Turn Signal-3157
INSTRUMENT CLUSTERS
Speedometer/gauge cluster-B8.5
(Will update with additional bulbs, HVAC, overhead console, ect)
Also, many of the miniature wedge base bulbs (921, 194, 168,) can often interchange, allowing you to use a brighter bulb, IF it will fit in the lens as far as the dimensions go concerning height, width, etc...
Here's another source for LED bulbs, resistor packs, etc...that does very well with their quality and customer service: AutoLumination
The website is a bit hard to follow but if you have questions, their phone customer service is pretty good.
If anyone wants to cross reference the 2nd gen bulbs, be my guest! I'll add it if it becomes available.
Sponsored Ad
Register to remove this ad.
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline
Closed Thread
Tags
4th gen leds
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Long time Jeep owner/ New Ram convert! mrtosh Introduction 21 07-05-2012 04:04 PM
Easiest & Cheapest way to convert to Leather fatwombat Interior 16 10-11-2010 04:39 PM
what does this convert to ..tire size ramhunter9 General Discussions 6 09-27-2010 11:23 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
