2013 Ram Dash Resetting
Yes, my truck is doing the same thing. I have taken it back to the dealership several times for this.
I left the shop today after having the console replaced under warranty. Apparently during assembly, the installer got in a hurry and pinched a wiring harness between the screw and the console thus flatting out the harness and breaking the plastic tab that holds it together.
I noticed it wasn't right because the plastic/rubber tray directly under the stereo/dash area wasn't fitting just right. I removed the tray and discovered the broken console.. Apparently this is NOT causing the dash to reset while in operation (According to the mechanic).
Onto why I am here!! After leaving the shop (Dodge Dealer) I drove about a mile down the road and the dash started the reset process, but when it came back on the throttle punched all the way to the floor causing me to lose control of the truck. I was able to turn the truck off and bring it to a stop in the middle of the road after almost hitting a guardrail.
I restarted the truck and returned it to the dealer. They plugged it in and noticed a ton of codes.
My best guess, there is a dead short or bad ground that is affecting the trucks computer. All the door locks except the drivers door are in-op as well now.
I left the truck there in hopes they can fix it.
Most of the issues started after the last recall update.
Hope any of this helps, if your truck is resetting while driving, i suggest you take it to the dealer asap. for your safety.
Contact me if you need any more info! Or for updates!
Kyle
