Differential oil
R.L.K.
Bristol , Tn.
Helo all , I'm about to change my differential oils in my 2014 RAM 4X4 QC 3.55 GR with Anti-spin rear end , only towing I do is my boat .
Open for suggestions on oil & additives type and wt.
I know what the owners manual says , I just would like to see what some of you guys are using .
I'll be using Redline oil and likely 75-140 rear with Anti-spin additive and 75-90 front
Thanks for a response !
R.L.K.
R.L.K.
Bristol , Tn.
I would like to know as well!
@ Jdperry , I reposted this over on 4th Gen Engine & Performance due to the lack of responses here in Tech .
A decent amount of discussion there ! Also in the ever popular Syn thread a lot of good reading on oils there as well .
I ended up going with Redline 75-90 in the front and 75-140 in the rear after some research , no anti slip/ limited slip additives required withe the Redline" GL " series oil . It's added already .
Enjoy the read !
Jdperry
Cleveland Tx
Enjoy the read !
Thanks for the update!
dunney
I'm installing a new LSD out back, and 75/140 with an LSD additive was what was recommended to me.
Of course, I'm still trying to install it, so fingers are crossed.
Good luck!
68Malibu383
Some of the gear oils have the additive in already so no need to purchase additional. Read the label when you buy the oil.
