Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Tech Info
Drive axle fluid change?
This is a discussion on Drive axle fluid change? within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Hey all- recently bought a 2012 quad cab sxt, and with 66k on it, the maintenance schedule shows next service ...
Like Tree1Likes
  • 1 Post By ColdCase
Reply
Old 04-26-2016, 10:06 PM   #1 (permalink)
Ram Year: 1996
Engine: 5.9
Default Drive axle fluid change?
Hey all- recently bought a 2012 quad cab sxt, and with 66k on it, the maintenance schedule shows next service @ 72k. I'm including a screen shot, which lists "drive axle fluid" as a item that needs changing, and differential fluid as an item whose level needs to be checked. I'm fairly mechanically inclined, so what am I missing here? I would think the only parts of the final drive holding fluid would be the diff's, front and rear. Any help clarifying would be much appreciated.
Chris
Sent from my LG-D850 using Tapatalk
Sponsored Ad
Register to remove this ad.
chrisc60 is offline   Reply With Quote
Old 04-26-2016, 10:07 PM   #2 (permalink)
Ram Year: 1996
Engine: 5.9
Default
Oops, forgot the screenshot, but you know what I'm talking about
Old 04-26-2016, 10:58 PM   #3 (permalink)
R.L.K.'s Avatar
Ram Year: 2014 4X4 QC Express 6 speed auto 355 differentials
Engine: 5.7 Hemi
Default
Just change the fluids , it's simple and quick to do. This way you'd know when it was actually changed .
Use the weight oil called out in the owners manual , verify if you have an Anti-spin ( LSD ) Rear differential , if you do have a Limited Slip Differential in the rear you will require not only the proper weight oil ( example 75-140) But an oil with friction modifiers in it already or you need to add the friction modifiers with the fill on the rear only .
I'll post up a thread on a how to , just need to find it .
Found it . This one is mine , a quick search you'll probably find a better one .
Hope this helps .
https://tapatalk.com/shareLink?url=h...0&share_type=t
Differential oil change
R.L.K. is offline   Reply With Quote
Old 04-27-2016, 12:49 AM   #4 (permalink)
ColdCase's Avatar
Ram Year: 2016
Engine: 5.7
Default
He was asking what is the difference between what the manual calls "drive axle fluid" and "differential fluid" as he is thinking they are the same thing.
R.L.K. likes this.
__________________
Current: 2016 1500 Big Horn Short Bed, 5.7 8 Speed
Past: 1990 Dakota 3.9, 2001 Dakota 4.7, 2006 2500 MegaCab Cummins
ColdCase is offline   Reply With Quote
Old 04-27-2016, 08:18 AM   #5 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
With 66K on it your diff oil don't need changing for 20 years. Lol.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 11-04-2016, 06:58 PM   #6 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
Hope this helps .
RLK, can you re-post your link, it is a dead link right now.
Im looking for a good right up on changing front and rear diffs, if anyone has a good one for info, like fill ports and drains. what sizes for drain plugs...etc..
beep119 is offline   Reply With Quote
Old 11-04-2016, 08:45 PM   #7 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
Here it is ... I just went to the link above and it went right to it ?
My post only covers the rear , but the thread covers more .
Hope this helps you Sir !
https://r.tapatalk.com/shareLink?url...0&share_type=t
Old 12-21-2016, 11:48 PM   #8 (permalink)
soldiercowboy's Avatar
Ram Year: 2014
Engine: Hemi 6.4l 4x4 Tradesman crew cab
Default
I changed my front and rear differentials today and just want to say it is harder than it looks. I have 2014 ram 2500 4x4 I do not have drain plugs so I had to pull covers off and replace gaskets I ordered from Tasca parts. The hardest part is getting wrench around the suspension parts and brackets and breaking the bolts loose. I used a large drip pan to catch the oil because it come out from everywhere on the bottom edge of cover. I also used a oil change mat I got from o'reilly parts to prevent oil on garage floor. The gasket I got is a stiff rubber type gasket I did not have to use any silicone. I just put gasket on cover and put bolts back in and torqued them down to 30 ft lbs. I highly highly recommend using a pump to refill oil because there is no room for a funnel and quart bottle to fill. I used redline 75w85 gl-5 oil in gallon jug. Filled until oil starts coming out of fill hole rear takes 1 gallon and about 3 qts for front. Hope this helps someone I had 33000 miles the rear was worse than front because I do not use my 4x4 very often but i will change them both at the same time. The rear was a dark oil brown color so it was a good time to do it. Dealer says 30000 miles on differential and 60000 on transfer. The next time I do this I will be changing the covers to one's that have a drain plug. Hope this helps someone if you have any other questions send me message I will respond as soon as possible. Thanks for reading
Sent from my SAMSUNG-SM-G890A using Tapatalk
soldiercowboy is offline   Reply With Quote
Old 12-22-2016, 10:59 AM   #9 (permalink)
Ram Year: 2015 Power Wagon
Engine: 6.4 Hemi
Default
the gaskets on the 2500/3500 are re-usable. no need to buy new ones unless they are damaged. i usually leave the top two bolts on (but loose) when popping off the cover. helps cut down on the mess. i have a pump but almost never use it. its faster/easier to just fill from the bottle, imo.
DannyMK2 is offline   Reply With Quote
Old 12-22-2016, 01:43 PM   #10 (permalink)
Ram Year: 2014
Default
Thanks for that information on the gaskets I will use the same one next time. I perfer the pump it makes it a lot easier imo.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Axle fluid quantity for 9.25/11.5 differentials? Hootbro Heavy Duty 6 10-12-2015 03:28 PM
need help with tranny fluid, filter and transfer case fluid change jon0m0berry 4th Gen DIY 10 05-12-2015 08:12 PM
Drive with no axle shaft? Arlucian Exterior 9 03-25-2015 12:52 PM
Rear and Front Axle Fluid? RoadKing General Discussions 0 01-01-2014 12:09 PM
Bubbles in Rear Axle fluid?? HisGirl Tech Info 1 07-07-2013 05:51 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
