mangus2k13ram
- Nov 4, 2013
- 157
- 24
- 2013
- 5.7 Hemi
If you are experiencing the bump when stopping, what size bed do you have on your truck, 5.7 or 6.4?
Was reading about the same problem on the 150 forums and it seems to be mostly the 6.6 bed. It has a split drive shaft for the extra length and this seems to be the cause for the bump.
The Ram 6.4 bed also has a split drive shaft so just curious to see if there is a correlation between the two.
I highly doubt that is the problem ram has been making that configuration for years and there has been others with crew cabs with the same issue.
