DRL Disable for 2012 Ram
Edmonton, Alberta
Hey guys. I recently found a contact at a Dodge dealership here in Canada that is working with me to get my DRL's disabled or changed so i can switch them to the LED strip on the new oem projectors I upgraded to, as currently they are the high beams half power.
We attempted to try the following the directions below, however my year of truck doesn't have a BCM (??), so we couldn't use this as other 2013's have succeeded with.
"Using the Chrysler Diagnostic Engineering Tool:
He selected the BCM, ECU Configuration 2 (CBC Features), DRL Configurations. From the drop down he selected Canadian DRL.
Next he selected DRL Lamp Location, (just below DRL Configurations) and from the drop down selected Turn Signal DRL.
Last, he clicked on the write button, cycled the ignition, and wala, DRLs are on again."
We eventually changed the country code to Mexico and this worked perfect as there was an option to turn the DRL's off. The only problem.... My built in Satellite radio shows the message "SAT Region Error" cause it thinks my truck is Mexican and they only supply to North America. LOL. Can anyone help??
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
So do you now have no DRL's or did you manage to get the LED's working as DRL's?
If you want to disable them why not set it to a US truck and turn them off? Then you shouldn't have any issues with the satellite radio.
Metric Customs
Edmonton, Alberta
I now have no DRL's but I was going to order a DRL module online to wire in if I want.
They were saying that when they tried the US settings, there was no option for DRL and when tested they were still on. Mexico being the 3rd choice had the option.
smoothee
St. John's, NL
Interesting. I've just ordered the module, and am planning on heading to the dealership in the next day or two to try and have them disable my current drl's. Hopefully I don't run into the same issue...
Metric Customs
Edmonton, Alberta
Let me know what happens! I am stuck between having no drls or having satellite radio.
Let me know if they fix it another way!
smoothee
St. John's, NL
Will do. They were busy yesterday and I was in a bit of a rush, so going to try again on Tuesday. I do have an aftermarket headunit too, so not sure if that'll make any difference to the satellite radio issue.
Metric Customs
Edmonton, Alberta
How did this end up for your? Did the disable work?
smoothee
St. John's, NL
Sorry, forgot about this thread. The first dealer looked at me like I was crazy and said it wasn't possible (I found out they're a ******/incompetent dealer anyway from my two first and last visits). Anyway, 2nd local dealer seemed to know what I was talking about and didn't seem like it'd be an issue. However it would be $115, so I'm still debating if I can justify such an outrageous cost. So right now I have two drl's, lol. For what's it's worth, the drl module works like a charm. I'm sure I will eventually break down and have the dealer disable it... I wish the dealer I bought my truck from and had all my services done wasn't on the other side of the country, I'm sure they'd do it for free.
EDIT: not sure why Bullydog has the ability to disable the drl's but not Diablo!
jwheeler
Washington
Unfortunately that is a pretty standard fee for performing updates, adding options or changing settings. People gotta get paid. But it would be nice if there was a way to get ahold of local techs on here that would be willing to do little stuff like that on the side for much less.
smoothee
St. John's, NL
Yeah, true enough I guess. Just a harder pill to swallow when it's something that you could probably do yourself if you had access to the tool. Gotta say, one of the things I like about the older 4th gens is you don't need the dealer in order to add every little option. That would be handy. I'm in a couple of local truck groups around, but haven't been able to track down a tech. Bummer.
Metric Customs
Edmonton, Alberta
I was lucky enough to know someone who's wife worked in the dealership, she got me my drls disabled but the truck is still Mexican haha. Where did you get your drl module from and how did it work?
Was there a big hassle wiring it in?
smoothee
St. John's, NL
That's handy, aside from the Mexican part, lol. I'm going to soon break down and have the dealer give it a shot, my curiosity is getting the better of me.
Got the module from Daniel Stern, and it works perfectly as intended so far. Just sucks that I've got two drls at the moment, lol. Install wasn't too bad at all, just tap into two wires on the driver side adapter, and cut and solder into 4 other wires (2 on driver side/2 on passenger). Take a look at this thread if ya haven't already.
http://www.ramforum.com/f96/amber_led_drls_13_projectors_finally-62260/
wrench04
Great White North
Once you get them turned off you can switch the country code back to Canada and they should stay off. I did this with my 2008 3500 and it worked well.
Sent from my iPod touch using Tapatalk
Metric Customs
Edmonton, Alberta
Did this provide you with a full power orange LED for daytimes or was it only half power? Also I am thinking of doing the white/amber switchbacks for my led strip. Have you heard anything to do with this?
Metric Customs
Edmonton, Alberta
Sounds like it might work. I don't think that getting the country switched back and then having the drls go back on would be a good idea. Then i'd be like, "oh jk can you actually switch my country code again" lol
smoothee
St. John's, NL
Yes it did. For the switchbacks you'd have to tear apart the light and replace the board.
Now that wrench04 mentioned it, that's how I've seen the other guys who have had luck with this do it. Change the country code, turn drls off, and then switch back to Canada. The drl's should remain disabled.
Metric Customs
Edmonton, Alberta
Truck looks good. I love those demon eyes. I am probably going to install the switchbacks, just wasn't sure if it would make the DRL module more difficult to install or not. I might give switching back the country code a chance..
smoothee
St. John's, NL
Thanks man, JJ does some slick work. Installing switchbacks wouldn't have anything to do with the module, as the module is mounted outside the lights.
RedFlameRam
