kabong57
- Jan 11, 2017
- 47
- 10
- Central IL
- 2017 3500 SRW 4WD Reg Cab Long Bed
- 6.4L
Seems 2017 has some wiring differences so need some help.I have a 2017 RAM 3500 Tradesman Reg cab/long bed/4wd/ 6.4 gas. Came from the factory with a 3.0 non-connect Radio, rear view camera with image in the rear view mirror.
#1 Would like pin-out of the tailgate connector so I can disable the tailgate lock with out breaking the Rhino lining seal of the access panel
#2 Would like to add a dash switch to temporarily kill the camera image in the mirror when hooking up the goose-neck trailer.
#3 Would like the option to import the factory camera signal into a stand alone TFT monitor. Ideal situation would combine #2 & #3 into one 3 position switch
image to mirror / image off / image to external monitor
This is my dream. Thanks
