front suspension TQ specs
JB1
Houston, Texas
2011 Dodge Ram 1500 2wd
  • Upper Balljoint Nut - 40 ft. lbs.
  • lower balljoint nut - 38 ft. lbs.
  • tie rod end nut - 45 ft. lbs.
  • brake caliper bolts - 130 ft. lbs.
  • center hub-spindle bolts - 120 ft. lbs.
  • swaybar endlinks - 20 ft. lbs.
roadrnnr
Vermont
Is the 4WD the Same?
jdavila99999
Same on 2016 1500 4X4?
1Popeye
