2010blueram
Hi,
I Have a 2010 Dodge Ram 5.7 Hemi. Last night it wouldn't start for my gf, so I thought she ran it out of gas. After putting 2.5 gals of gas in the tank and the level indicator on the dash reading above empty, it still would not start. I checked the full pump fuse with a multimeter and it tested good. I took off the intake line to the throttle body and poured in a tiny bit off gas. The truck started right up, but died when the gas burned off.
What else can I check before committing to replacing the fuel pump?
No engine codes are present.
