FYI: Recall on '13-17 2500/3500's w 6.7l Cummins
O.R.T.
Wessyyydddeee
re: https://www.allpar.com/news/2017/09/ram-water-pump-recall-38466
Mods, not sure but maybe this should be a sticky?
Ram water-pump recall
by David Zatz on September 19, 2017 at 1:44 pm EDT
Ram is recalling around half a million 2013-17 pickups and chassis cabs with Cummins diesels, after discovering that trucks built with a certain water pump could, due to a bad bearing, cause an engine bay fire.
FCA US is not aware of any related injuries or accidents, and no longer uses that water pump.
Owners may have advance warning: when the bearing starts to fail, it may activate a warning light in the gauge cluster. If this happens, it should be taken immediately to the dealer.
The company’s US Recall Information Center is at (800)-853-1403. The recall appears to be global.
O.R.T.
O.R.T.
Wessyyydddeee
Yup.
FWIW I CC'd this topic into the 4thGen Cummings part of the board so those members also can see this. When I got the main message it skipped off because I'm not at the dealership anymore. Hopefully nobody has to face the bigger issue.
