Ram_37d
- Feb 6, 2016
- 2
- 0
- 2012
- 6.4 cummins
I have a 2009 1500. A noise started gradually in the front end. It has got worse as of late. Sounds like a bearing going down in the right front. When I am driving I swerve to the right the noise stops driving straight the noise exists. Or turn left it still there. Sounds like a wheel hub assembly. I replaced the wheel hub assembly and the cv shaft just to cover my basics. Taking the cv shaft off turned out to be a big deal.... To take the cv shaft off the output shaft of the housing, I took the outer seal off and pulled the 4 wheel drive short lock up shaft out with it. That bearing the outer bearing on the housing,The race was spinning in the housing and the bearing was rough I replaced both. Peaned the housing installed a new race and bearing."the new bearing was tight after install" After putting it all back together confident I found the problem. Took the truck for a test drive and the noise still exists from the right front. I'm at wits end. Any idea from anyone help would be appreciated... Thanks
